economical durable paint?? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 06-08-2013, 05:53 PM
looking for best paint lowest price on OEM 1989 Gm paint code 27 light blue metallic & code 98 black sapphire met. any ideas? Im an old DuPont man. but what I use to paint is no longer available. need updated on todays paints! thanks for any help.
Old 06-08-2013, 07:07 PM
Northstar T's Avatar
Gone sailing
Not sure that's possible, but I've had very good success with Montana (Big Sky) system 22 acrylic urethane.
Russ
Old 06-08-2013, 07:43 PM
first ive herd of that brand ??????
Old 06-08-2013, 08:15 PM
BOBCRMAN@aol.com's Avatar
www.smartshoppersinc.com Been using them since the early eighties
Gone sailing
I have a local dealer, but here's a link to give you an overview of Montana products. I've used their epoxy primer and some base/clears as well. never had a problem with any of them.
Welcome to Montana BIG SKY at Terry's Auto Paint Supply!
Russ
Old 06-08-2013, 09:39 PM
thanks but im in California. will try and find a store around hear.
is that a Studebaker? my boss id looking for rear finders for a pickup???
Old 06-08-2013, 11:46 PM
33Willys77's Avatar
I use Wanda and love the paint and primer. Easy to use and lays down like glass and holds a very impressive shine - even the single stage paint is very hard to tell apart.
Old 06-09-2013, 12:05 AM
wanda?? never herd of that ether. Kirker seams to be reasonable to me.
Old 06-09-2013, 09:32 AM
33Willys77's Avatar
Look up Wanda (simple google). It's been around since the early ages and made by Akzo Nobel. I rank it right up there with the European paints (Glasurit, Standox, ICI (now Nexa)) but without the high pricing. Great color matching and they use the same hardeners and reducers for all the products, from primer through clearcoat. I was very skeptical, but once I tried it, I will not spray anything else - and I work on some very high end show cars.
The Following User Says Thank You to 33Willys77 For This Useful Post:
Anthonyaa (06-09-2013)
Old 06-09-2013, 09:40 AM
deadbodyman's Avatar
Wiki Edits: 11
Everyone has good things to say about Wanda paints. I'll be trying it also.
Old 06-09-2013, 10:27 AM
Ok I will look in to Wanda sounds like what I'm looking for. kirker sounds good also but doesn't have a match for my light blue
Old 06-09-2013, 11:52 AM
Banned
why not use duponts econo brand nason
Old 06-09-2013, 12:21 PM
Nason? like I said I haven't been in to painting in like 15+ years. All these suggestions are very much appreciated. I am looking in to every option. This is what Im up against, I bout the truck from an older lady who's husband died of cancer. under the impression that I would put it back to OE condition.
Old 06-09-2013, 12:54 PM
wow! tried looking up Wanda paints and the closest one is like 150 miles from me and when I tried to googol directions it will not give them. so what I would spend on gas and time. don't think Wanda is an option.
Old 06-09-2013, 09:42 PM
Wiki Edits: 11
A couple years ago Nason was my econo paint I liked it and got good results but Last week I called about some SS black and its 195.00 a gallon now and with the hardner you only get 4qts and a pint of mixed paint.Spi is what I bought it cost 125 for a gallon with the hardner and I get 5 qts of mixed paint I sprayed it and holly crap thats some great paint slick like glass and sprays like the high dollar SW SS paint that until now I thought was the best I ever sprayed as far as SS goes...SPi only has a few colors though and I wouldnt use a SS paint if its not a solid color...
economical front solid axle, brakes, spindles? gregsdart Hotrodding Basics 3 11-24-2012 02:39 PM
1968 Dodge Charger Cheap Durable Paint Job you50.com Body - Exterior 15 04-23-2011 02:50 PM
Economical ways to increase horsepower Apollo Hotrodding Basics 10 11-08-2006 03:30 AM
Good durable paint for frame?? BadA$$37 Body - Exterior 27 09-24-2006 02:04 AM
WHY! are the slowest drivers always in the most economical cars? bullheimer Hotrodders' Lounge 12 08-08-2005 11:40 PM
