Economy fuel injection - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2006, 06:24 PM
I have a 283 SBC w/4 spd and 2.73(currently)gears in a 5 window 28 Ford coupe. I currently run a Holley 600 CFM on an Edelbrock Performer RPM manifold. I would like to change over to Electronic Fuel Injection but I am short on cash and don't have the money for the conversion. I mainly would like the reliability and cold start manners of fuel injection. Does anyone know how and what I need to convert to old time TBI system? I know the performance will not match newer injection and or carburetion.
Thanks - Jerry
Old 11-28-2006, 07:05 PM
Wiki Edits: 31
TBI manifold ect from 305, and a controller, weather it be a stock controller or a custom. also a high preassure fuel pump and regulator
Old 11-28-2006, 09:57 PM
tbi upgrade
try Howell engineering for a cheap wiring harness $300 the go get all necessary part off of a 87-95 chevy truck.the fuel pump you can purchase from howell $95
Old 11-29-2006, 09:47 PM
Economy Fuel Injection
Thanks for the info, now I know what direction I want to go.
Old 11-30-2006, 08:54 AM
Check out megasquirt.com
They have a cheap DIY system. I would recommend getting the version with ignition timing control for the best mpg possible.
Old 11-30-2006, 09:34 AM
A 283 with a large throttle body like the ones off the 5.7L motors would lose very little power unless you're going to rev it to the moon.
Flatehead Fuel Injection 4811 Engine 2 08-22-2005 04:56 AM
ford 302 fuel injection and aod trans 39 chev Engine 13 08-19-2005 10:49 PM
Help with fuel injection settings EazyDuzIt102 Engine 11 07-21-2005 10:57 PM
Device for vaporizing fuel to improve economy released onto market today! club327 Engine 15 05-25-2005 08:47 PM
O2 fuel injection and simplicity NXS Engine 15 05-24-2005 01:33 PM
