Ecu?
Hello there I have an 86 monte carlo ss and I was looking for the ECU but it does not have one should it have one?
I have had the car for 2+ years now and it seems to run fine. with this being a carb motor do I really need one and why would the last owner have taken it out. any suggestions would help. thanks Eric
Hi,
Your car should have an ecm, you have a feedback carb or at least that's what it came with new, I can't remember if the dist is ecm controlled or not. Rich |
ecu
thks the carb is a Rochester 650 i believe I cant see any electric hooks on the carb except for the choke should there be if it needs a ecu?
If it was stock it would probably have a big solenoid parked down in the front of the quadrajet running the mix on your primaries, and those carbs need TLC to run without the ECU. A stock dizzy will have two spark-modification wires coming out of the body and heading into the firewall, a non-computer HEI is a drop-in and only uses the 12V hot plus a tach wire, if equipped. I had a Malibu of that era, I just abandoned the ECU in-place, IIRC it's mounted somewhere on the passenger side kick panel or firewall
ECU should have been under pass dash, most were removed due to they where crap and a normal carb and dis were installed.
ecu
thanks for the input ya its a HEI dis,
| Can I eliminate the ECU from the engine completely now? | 5_speed | Electrical | 10 | 01-18-2009 10:30 AM |
| Chevy ECU | Sir Joab | Engine | 2 | 01-24-2007 04:03 PM |
| MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU | izord | Electrical | 0 | 09-06-2004 02:16 PM |
| ECU wiring 5.7 L TBI | carloss | Electrical | 11 | 10-06-2003 04:45 PM |
| Megasquirt ECU | TurboS10 | Engine | 11 | 09-26-2003 07:15 AM |
