-   -   ECZ-9425-B 292 Intake Manifold (http://www.hotrodders.com/forum/ecz-9425-b-292-intake-manifold-145997.html)
B52_Bomber 10-02-2008 03:52 PM
Looking to install a ECX-9425-B on my 292 in my 56 Ford f100. On the intake, there is a tube that runs from one side of the manifold to the other side which I believe is connected to a mushroom like valve. The tube is broken inside and the mushroom like valve has rust holes in it. I believe this is used to heat the choke on the carb. Sense I plan to use an electric choke, is there any reason why I could not remove it and plug the holes?
Let me know, thanks!
oldbogie 10-02-2008 04:29 PM
none at all
Bogie
B52_Bomber 10-02-2008 04:45 PM
Thanks Oldbogie!
I didn't want to screw things up without getting the lowdown on it.
