ECZ-9425-B 292 Intake Manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2008, 02:52 PM
Looking to install a ECX-9425-B on my 292 in my 56 Ford f100. On the intake, there is a tube that runs from one side of the manifold to the other side which I believe is connected to a mushroom like valve. The tube is broken inside and the mushroom like valve has rust holes in it. I believe this is used to heat the choke on the carb. Sense I plan to use an electric choke, is there any reason why I could not remove it and plug the holes?
Let me know, thanks!
Old 10-02-2008, 03:29 PM
none at all
Bogie
Old 10-02-2008, 03:45 PM
Thanks Oldbogie!
I didn't want to screw things up without getting the lowdown on it.
Altima GXE Intake Manifold Gasket awbazar Engine 5 01-24-2010 07:45 AM
intake manifold is messed up, need help picking another 84Z Engine 1 08-21-2007 04:57 AM
Intake manifold volume techinspector1 Engine 8 07-13-2007 10:43 PM
Replacing Intake Manifold Questions RObs71Nova Engine 1 01-21-2005 10:37 PM
Intake Manifold Bolts - Need Sleeves?? jerseyjeff Engine 5 11-18-2003 01:00 PM
