Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Eddy Carb hesitation off idle.
Old 06-13-2012, 08:04 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by cobalt327
The PCV is fine where you have it. The hesitation is likely either the vacuum advance falling out (if connected to manifold vacuum and supplying more than 10 degrees of vacuum advance) or the accelerator pump circuit is not supplying enough pump shot, or the pump shot duration is insufficient. Or a combination of these.
Different size shooters are available or drill yours. If you drill too big- which you may do if searching for the "perfect" size- solder them shut and re drill to the correct size as determined by testing. Then if you want, you might be able to buy a new shooter of the correct size or get one as close to the right size and drill it. This is because sometimes getting a good spray pattern from a soldered over and re drilled shooter is hard.
And again- you have to get a pump shot the instant the throttle linkage moves. You can buy an accelerator pump piston assembly separately, same page as above.
I do have the vacuum advance can going to full manifold vacuum. I heard so much about how full manifold is the way to go but I guess in my case it will help with the idle transition by switching to the ported. I wanna start looking at getting an AFR gauge. It would make tuning so much easier.
