Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Eddy Carb hesitation off idle.
Old 06-14-2012, 04:59 AM
75gmck25 75gmck25 is offline
Based on your original question, I'm not sure when you are feeling the carb drop out. If its during mid-throttle to full throttle you need to check the step-up springs in the Edelbrock.
These springs work against vacuum to transition the rods from cruise to power. In cruise mode vacuum pulls the rods down against the springs and the carb runs relatively lean. When vacuum drops during acceleration the springs push the rods up into power mode. If the spring pressure vs. vacuum is off, the transition to power mode is too slow. Edelbrock sells a set of springs that are rated in 3" to 8" of vacuum. A higher rated spring transitions to power mode sooner, which can help part-throttle bog.
Bruce
