Eddy Carb hesitation off idle. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-15-2012, 02:22 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by 75gmck25
Based on your original question, I'm not sure when you are feeling the carb drop out. If its during mid-throttle to full throttle you need to check the step-up springs in the Edelbrock.
These springs work against vacuum to transition the rods from cruise to power. In cruise mode vacuum pulls the rods down against the springs and the carb runs relatively lean. When vacuum drops during acceleration the springs push the rods up into power mode. If the spring pressure vs. vacuum is off, the transition to power mode is too slow. Edelbrock sells a set of springs that are rated in 3" to 8" of vacuum. A higher rated spring transitions to power mode sooner, which can help part-throttle bog.
Bruce
Its full throttle launches from a dead stop. If I get up on the converter and ease into it there is no problem.
  #17 (permalink)
Old 07-11-2012, 01:09 PM
Listen and Learn
Wiki Edits: 7
Well I think I figured out why my car was stalling on the corners. The passenger side metering rod got bent and wasn't even inserted into the hole in the base of the carb. I haven't had a chance to take it out on a cruise since I fixed it but im hoping that fixed the cornering issue.
I readjusted the float level and the hesitation still continues. I am gonna get a tune up kit and try swapping out the step-up springs to something that will transition sooner.
carburetor, edlebrock
89 Throttle body 350 rough idle and hesitation martee373 Modern Electronic Engines 35 02-11-2012 03:55 PM
Chevy 350 off-idle hesitation Yardstick Engine 4 04-03-2007 10:07 AM
wierd hesitation is it carb? tinman386 Engine 1 11-09-2006 06:49 AM
Carb. hesitation Slant3 Engine 4 08-22-2004 01:59 AM
Holley - hesitation off idle snod83 Engine 1 06-14-2004 03:48 PM
