Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - edelbrock 1405
Thread: edelbrock 1405
Old 12-18-2011, 05:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Linez35
ive got an edelbrock 1405 carburator on a chevy 350. i was wondering what size of jets and metering rods would it take to help wake up this 350..
If you've not yet done so, get the timing sorted out first. The initial timing, total timing and vacuum advance has to work in concert for best performance and economy. The cam will have a lot to do w/the timing requirements along with other engine mods, the type and material of the cylinder heads, the compression ratio, final drive ratio, vehicle weight, how you drive it, the gas quality, etc.
Once the timing is right, start in on the carb. The performance and plug color are good indicators of the carb tune.
Your 1405 uses the Edelbrock p/n 1479 recalibration kit
Use the Edelbrock Owners Manual to tune the carb. In most cases I recommend that the carb be baselined back to stock to begin with. The 1405 came with:
100 x 95 jets
70 x 47 rods
Orange (5) step up springs
There are tables (the 1405 is at page 20) that graph out what changes made to the step up springs, rods and jets do to the air/fuel mixture.
