-   -   Edelbrock 1405? (http://www.hotrodders.com/forum/edelbrock-1405-a-152280.html)
muzzfactor 01-28-2009 04:24 PM
Edelbrock 1405?
Ok guys, I'm in the process of trying to tune my 1405 and I read so many of the previous posts that they all start running together. I've ordered the fuel pressure regulator so I can adjust the pressure to between 5 & 5 1/2 lbs but now I can't remember which way to turn the two adjustment screws on the front of the carb. Is it "in to lean" & "out to richen"? I want to get all this right so I can hopefully get this truck up and running like it should. Thanks.
Henry Highrise 01-28-2009 04:28 PM
Go to www.edelbrock.com and print out a manual for your carb. Here is a link to download a manual http://www.edelbrock.com/automotive_...ers_manual.pdf
runn141 01-28-2009 05:29 PM
you have it right, "in to lean" and "out to richen".
Bryan59EC 01-28-2009 08:37 PM
Good starting point
Turn in all the way, til lightly seated
Back out 2 full turns
This will usually get you pretty close
muzzfactor 01-29-2009 06:35 PM
Ok guys I've got another question. the fuel pressure gauge is erratic bouncing from 4 - 5.5 lbs while at idle, but once you push on the throttle it calms down and settles in a 5.5. Is this correct or do I need to adjust it further? Now another problem has reared it ugly head, once i shut the truck off it's now "dieseling" for about 2 seconds. What causes that? Thanks.
runn141 01-29-2009 06:40 PM
my guess is, a vacuum leak. somebody correct me if im wrong.
Bryan59EC 01-29-2009 06:58 PM
Stuttering fuel gage won't be an issue
Dieseling:
Throttle plate is not closing
too rich an idle and dribbling fuel
Perhaps idle was adjusted with engine cold and on one of the choke steps
Timing outta whack.
This Edelbrock replace a q-Jet??????
If so---you will need the adaptor plate to avoid vacuum leaks.
Perhaps the engine decided it did not want ported vacuum advance :confused:
Why the carb change???
Is this on the Pontiac---or the Chev pu??
The chevy may have a computer issue and does not like the non electronic Eddy carb.
Just tossin' crap out for ya.
If it is any consolation to ya---I'm still trying to get issues ironed out the Elky.
muzzfactor 01-29-2009 07:24 PM
Hey Bryan, this carb is on the 350 motor that I have in my '84 p/u. It doesn't have any computer stuff on it. My idle may be a little high, I'll try and drop it a little and see if that helps. Thanks and take care.
Torque454 01-30-2009 03:36 PM
Im new here so im not sure what your vehicle is or what youve done to the engine or anything else but if you have a big cam and the engine lopes, maybe that is why the pressure is irratic at idle.
Bryan59EC 01-30-2009 08:19 PM
This is a thin plate that requires 2 gaskets-----you WILL have vacuum leaks w/o it
Torque454------84 Chebby 1/2 ton
I think it is stock---not sure tho---been awhile since I've seen Muzz
