edelbrock 1405 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2011, 07:11 PM
edelbrock 1405
ive got an edelbrock 1405 carburator on a chevy 350. i was wondering what size of jets and metering rods would it take to help wake up this 350..
Old 12-17-2011, 07:52 PM
kleen56's Avatar
Jets and metering rods won't wake up a motor. You need dial in the carb from what you have. Start by checking the spark plugs to determine the color. They should be a tan brown color. If they are white, your too lean, if black too rich. If you really want to mess with the rods, I'd buy a Edelbrock performance kit which comes with jets and rods and a diagram on how to get the most performance out of your carb. You can set Edelbrocks up for economy or performance.
Old 12-17-2011, 11:33 PM
okay thank you very much.
Old 12-18-2011, 05:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you've not yet done so, get the timing sorted out first. The initial timing, total timing and vacuum advance has to work in concert for best performance and economy. The cam will have a lot to do w/the timing requirements along with other engine mods, the type and material of the cylinder heads, the compression ratio, final drive ratio, vehicle weight, how you drive it, the gas quality, etc.
Once the timing is right, start in on the carb. The performance and plug color are good indicators of the carb tune.
Your 1405 uses the Edelbrock p/n 1479 recalibration kit
Use the Edelbrock Owners Manual to tune the carb. In most cases I recommend that the carb be baselined back to stock to begin with. The 1405 came with:
100 x 95 jets
70 x 47 rods
Orange (5) step up springs
There are tables (the 1405 is at page 20) that graph out what changes made to the step up springs, rods and jets do to the air/fuel mixture.
Please Help-edelbrock 1405 On Chevy 350 81elky Engine 2 07-15-2009 10:08 PM
Edelbrock 1405? muzzfactor Engine 9 01-30-2009 08:19 PM
? about the linkage on my 1405 Edelbrock Streetmaster Engine 2 08-15-2005 11:42 PM
Edelbrock 1405 no top end 85CHEVY Engine 4 08-07-2005 05:54 PM
Edelbrock 1405 4barrel jpd37 Engine 17 10-06-2004 12:37 PM
