Edelbrock 1406 help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2006, 01:38 PM
tommytempest's Avatar
I figured this might be quicker than Edelbrocks tech line. I bought a 72 Toyota FJ40 with a 327 with mild cam, torquer intake and ebrock 1406 carb. It runs REALLY rich. Anyone know which rods, springs and jets I should be using?
Old 03-10-2006, 03:06 PM
Twistedwrench's Avatar
No officer I wonít do it again
Pages 10-19
http://www.edelbrock.com/automotive_...ers_manual.pdf
Old 03-10-2006, 04:00 PM
twisted wrench...your link is for the thunder carbs...he needs the performer carbs link (I don't have it)
tommy tempest, the 1406 tuning manual also is on the Edelbrock site...but is based on a dual plane for suggestions
there is a 1406 tuning kit of rods/jets/springs ($35?) for mix and match....don't know if it is the best range for a open plenum...
I'd call Edelbrock....
Old 03-10-2006, 06:30 PM
Rhansen's Avatar
Footbraker
look here
http://www.edelbrock.com/automotive/eps_intro.html
Old 03-10-2006, 06:59 PM
Thatís the same link I use for performers, it says performer series and thunder series right on the first page. If it doesnít lead to that and just goes to thunder I donít what the deal is? I just hit the link myself and it went there. Maybe it just goes there when I hit it because I left it or something. Computers I guess. Anyways, I tried, sorry guys.
Old 03-10-2006, 07:52 PM
I actually finally got through to Edelbrock, and they verified that my jets, metering rods, and springs are the originals, which if anything should be a little on the lean side. They suggested my fuel pressure might be too high, so I pulled the fuel line and hooked it to my guage and get 5psi while cranking the engine. They said 4-6 is optimum, so that not my problem. Let me give a little more history. I bought this car as a basket case with no wiring in it, so I never heard the engine run until just this week after I got my harness in. No idea how long it has been since it ran last. The PO claims only a year, but I'm guesing longer. The float bowls are very clean, and I had the tank rinsed and ran all new fuel lines. i pulled the plugs before i ever got it started (squirted oil down the cylinders) and they were all pretty black. I have had it running for 20 minutes at a time 2 or 3 times now. It actually loads up a bit as it idles, and when I rev it, it just belches black. It starts and runs very well in spite of it being rich. I haven't checked the timing yet as the mallory distrib was never pulled. I will check it, but that shouldn't make it run rich. I know I need to get rid of the torquer and put my performer on, but I don't think that's going to change my mixture either. Another thing Edelbrock told me was that for offroading these carbs the off road needle and seat work well along with plugging the passageway between the 2 float bowls. Hadn't heard that one before, but its straight from the horses mouth, so it must work!
Any other ideas?
Old 03-10-2006, 09:08 PM
I have a 1406 on 318 in a van. When the carb had stock jetting it was running so rich that it got 11.5 mpg on the highway. By using jetting reference #12 in the carbs owner manual and leaning the secondaries 1 step the mileage increased to 15 mpg hwy. Basically this set is stock metering rods with .095 primary jets and .092 secondary jets. In order to run this lean I had to change to the plain colored step up spring to get rid of a part throttle stumble. Keep in mind this is with a very mild cam, 204 degrees @ .050 intake. If you're running more cam than this you might not be able to run this lean.
Old 03-10-2006, 09:22 PM
Just looked at my cam card, and it is a 212 duration at .050 and .446 lift. Pretty mild. Also, I live at a low elevation and am taking it to Moab Utah next month, so I should probably go a little leaner to compensate for the altitude as well. They run even more rich at high altitude right?
Old 03-11-2006, 09:31 AM
twisted wrench...apology...I guess that's a new web page for the manual(s)
tommy tempest...my .$02...drive it atleast 500 miles.... then pull the plugs and check for white/tan/wet/black etc....no load running in the garage won't tell you rich or lean
Old 03-11-2006, 01:32 PM
Hey, no prob. Glad you verified that the link was right. I was thinking I had lost my mind. Dang pills I am on makes a person think crazy things.
Tommy I cant believe you got through to edelbrock! I have given up many times trying to get in touch with them. I found their web site is a lot faster for most things.
How do you rate? I am jealous now. Lol
Old 03-11-2006, 10:14 PM
That's right the higher the altitude the more you have to lean the carb. Unless it is a high dollar hand built carb most all aftermarket carbs come anywhere from a little rich to very rich. Both edelbrock and holley would rather foul a few plugs than burn up a motor. They don't know if the buyer is going to be able to jet the carb or not so they're going to start out rich.
Bye the way when you look at the jetting figures I posted keep in mind that my local altitude is around 550-650 feet.
Old 03-12-2006, 05:50 AM
Thats pretty close to my altitude here which I believe is 600. That makes sense about them shipping them rich. Also, since this motor hasn't been run for at least a year, I should probably run it for awhile and maybe put new plugs in it before I get to excited about leaning it down. I will get the tuning kit though, and bring it and the tuning chart to Moab. Also, I am going to take the torquer off and put on a performer that I have laying around.
Thanks
Tom
Old 03-12-2006, 10:32 AM
Because it has set awhile I would get a new top gasket it might tear when you take the airhorn off to change jets. A complete rebuild kit and cleaning wouldn't be a bad idea for anything that set a year without running.
Old 03-12-2006, 10:21 PM
Ooops, I hit back and this reposted. sorry...............edt button wont let me delete the post...........Just looked at my cam card, and it is a 212 duration at .050 and .446 lift. Pretty mild. Also, I live at a low elevation and am taking it to Moab Utah next month, so I should probably go a little leaner to compensate for the altitude as well. They run even more rich at high altitude right?
1406 edelbrock problems Blackdog Engine 18 05-11-2013 05:20 PM
Edelbrock Performer head #60909 Houman SS '70 Engine 4 01-20-2009 10:56 PM
Need help with Edelbrock carb Crazy-J Engine 1 06-01-2005 03:24 PM
1406 edelbrock carb electric chock hook-up mferris72 Engine 1 09-03-2004 07:41 PM
edelbrock carb 1406 or 1411? MopaRV Engine 7 07-30-2003 02:07 AM
