Edelbrock 1406 rebuild question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2013, 03:50 AM
adam83's Avatar
When rebuilding a 1406, can you dip the body? I remember my mikuni carbs had rubber bushings on the butterfly valves and could not be dipped. Never rebuilt an edelbrock, but it looks like a straightforward process, just want to make sure I dont ruin any internals by dipping it.
Old 06-28-2013, 06:27 AM
Irelands child's Avatar
Dip it - nothing to hurt but aluminum and steel;
These two 1405's were recently done with the stuff shown:
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
Slammedsi (06-28-2013)
Old 06-28-2013, 07:23 AM
adam83's Avatar
cool
Old 06-28-2013, 08:28 AM
Banned
before you go too far check the throttle shaft play in the carb, edelbrocks are notorious for wearing there and it is a PITA to fix.
When I did them I would also take a fairly thin and fine cartridge roll and smooth over the casting lie as well, there seems to be a lot of them in an Edelbrock carb, it may or may not do much but I felt it helped slightly with metering signal. You can also fill in some areas with epoxy and smooth them over to get a more contoured path- all little things that can help but don't HAVE to be done.
Be sure to thuroughly clean the air passages on the carb, those have always been the problem areas for me.
Old 06-28-2013, 08:43 AM
Slammedsi's Avatar
Its nice to see people take there time and set out everything in an orderly fashion. Keeps a person from loosing anything.
Old 06-28-2013, 01:03 PM
Thanks. I either get anal about neatness or go 180 degrees the other way and am beyond messy
Irelands child
Edelbrock 1406 hesitation Rhansen Engine 22 03-17-2013 11:34 AM
Edelbrock 1406 question wot lean Eric64 Engine 11 07-06-2012 04:39 PM
Edelbrock 1406 elwaupo Engine 5 12-19-2011 06:46 PM
Another edelbrock 1406 carb question 99 to Life Engine 9 06-28-2011 05:32 PM
Edelbrock 1406 help please tommytempest Engine 13 03-12-2006 10:21 PM
