Edelbrock #1406 Tuning - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2010, 01:25 PM
Sinister's Avatar
Tuning my Edelbrock #1406 on my fairly stock 350 using a wide band O2 sensor. Motor is in a '69 C-20. .098" Primary jets, .073" x .042" Primary metering rods, .101" Secondary jets, stock step up springs which I think are yellow. WOT throttle is good 12.5-13 AFR, cruise is good around 14, light acceleration is good around 13. Driving up the hill to my house it goes lean around 15.5 AFR. Haven't put a vacuum gauge on it driving up the hill, but at idle I'm pulling around 20 inches. Should I try some richer step up springs? Trucks drives good now, I'm just concerned about it being lean under load.
Old 04-09-2010, 11:35 AM
I would go one larger and see... if you've upped the rest from Edelbrock stock than it stands to reason.
How's your timing? Do you use a vac advance?
Old 04-09-2010, 12:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I believe you're right- I'd go w/orange springs. Let us know how it goes.
Old 04-09-2010, 12:26 PM
Sinister's Avatar
Timing is 12 BTDC, still have to check total. Running vacuum advance. I'll try the orange springs and see how it goes. Thanks guys.
Old 04-09-2010, 07:25 PM
Sinister's Avatar
I'll have to check and see if I have those rods. I'm going to try a spring change first to see where we're at. Numbers are good, just a little lean on that damn hill.
Old 04-11-2010, 12:11 PM
Sinister's Avatar
Well, tried both orange and pink springs with no appreciable difference. Since my other numbers are so good I'm just going to keep running the yellow springs. I can live with the 15.5 AFR running up the hill, I'm not pinging or anything.
Old 04-13-2010, 10:43 AM
Sinister's Avatar
Success. Tried some .073" x .037" metering rods and that did it. 14-14.5 AFR coming up the hill.
Old 04-13-2010, 01:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Too bad most guys don't report back w/their findings like you just did- the forum would be richer, knowledge-wise, if they did.
Thanks.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Vintage SCB cross ram tuning issues (Edelbrock X C8) 30fordhotrod Engine 12 08-17-2007 08:44 PM
Edelbrock Pro-Flo Problems Unkie Engine 11 05-22-2007 06:20 PM
edelbrock carb 1406 or 1411? MopaRV Engine 7 07-30-2003 02:07 AM
Tuning an Edelbrock carb..help I'm gaging! HotRodF100 Engine 5 04-28-2002 10:13 PM
