edelbrock 1406 vacuumn ports - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2013, 06:40 PM
hey my edelbrock 1406 carb i was wondering where do the tranny,brakebooster,distributor vacuum,intake modulator go for vacuum ports on carberetor,and intake manifold
Old 03-03-2013, 07:10 AM
delawarebill's Avatar
carb ports
if memory serves me.. lg on front goes to PCV, small front right goes to dist., lg on rear goes to tranny.
now this is for a chebby as the small front right has vac till u hit the gas and it'll drop.. the left side get vac when u hit the gas but zero at idle.
The Following User Says Thank You to delawarebill For This Useful Post:
liljoe1996miller@aol (03-03-2013)
Old 03-03-2013, 08:48 AM
81 Vette
Large port in front middle for pcv valve. Passenger side front is ported vac for dist. drivers side is full vac for dist. Large port in rear is for power brake boost and the tranny should go to manifold vacuum. Hope this helps
The Following User Says Thank You to spikebot 81 For This Useful Post:
Old 03-03-2013, 08:50 AM
Irelands child's Avatar
Best look at the owner's manual for these carbs for the port designations:
http://www.edelbrock.com/automotive_...404_manual.pdf
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
Edelbrock 1406 hesitation Rhansen Engine 22 03-17-2013 10:34 AM
Edelbrock 1406 elwaupo Engine 5 12-19-2011 05:46 PM
Edelbrock 1406 jetting Rhansen Engine 9 04-14-2010 05:24 PM
Edelbrock #1406 Tuning Sinister Engine 7 04-13-2010 12:14 PM
Edelbrock 1406 help please tommytempest Engine 13 03-12-2006 09:21 PM
