edelbrock 2101 & 1405 HEAT? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2005, 12:41 PM
Hey guys,
Ive got an edelbrock 2101 aluminum intake and a 1405 600cfm performer carb on a stock SBC 350. Can I get away with not running a spacer plate between the two to dispurse heat. I was told I should have a spacer in there.
Thanks
Old 06-23-2005, 01:01 PM
I wouldn't think you'd need one. The purpose of a spacer (usually) is to get a slightly better fuel atomization and if its made of some special heat deflection metal, to get a slightly better cooler fuel charge. It might decrease the fuel temperature for the first few minutes, but if it's underhood, it all starts to heat up anyway and any fuel differential you originally had is gone. Now that didn't answer your question.. I'm not too familar with the intake and carb you described and you may NEED a spacer for the bolt combination.. thats another story altogether. Hope this helps a little.
Edelbrock 1405 4barrel jpd37 Engine 17 10-06-2004 12:37 PM
The Edelbrock #1405 Carb - again Charles F. Smith Engine 2 06-19-2004 12:00 PM
Edlebrock or Holley? MeligN Hotrodding Basics 19 04-30-2004 04:48 PM
Edelbrock 1405 problem BrackneyC Engine 26 09-23-2003 10:48 AM
Edelbrock 1405 question BrackneyC Engine 3 09-08-2003 09:40 AM
