Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Edelbrock 2102 cam timing in 350
Old 09-11-2012, 09:03 AM
Custom10's Avatar
Custom10 Custom10 is offline
my KARMA ran over my DOGMA
Last journal entry: SS
With both dots/marks @ 12 oclock you are at #1 cylinder at TDC, crank dot at 12 oclock and cam dot at 6 oclock (lined up close together) you are #6 cylinder at TDC.
As mentioned the set you have will work fine straight up.
