Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Edelbrock 2102 cam timing in 350
Old 09-11-2012, 10:30 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
A new stock replacement or perf SBC timing set will not be retarded.
This note refers to smog era Ford V8's like the 351C.
Normally you do not need to adjust the cam phasing.
If you want to play you must degree in the cam before moving it.
Do not guess. Do not monkey with without degree ing it.
The cam "advance" is already built into the cam.
