The cloyes chain that you have will work fine. Install in the "straight up" position (no advance and no retard). Read the timing chain instructions, as there should be 3 different positions. Make sure you use the correct keyway for the crank gear for the straight up position. |
With both dots/marks @ 12 oclock you are at #1 cylinder at TDC, crank dot at 12 oclock and cam dot at 6 oclock (lined up close together) you are #6 cylinder at TDC.
As mentioned the set you have will work fine straight up. |
A new stock replacement or perf SBC timing set will not be retarded.
This note refers to smog era Ford V8's like the 351C. Normally you do not need to adjust the cam phasing. If you want to play you must degree in the cam before moving it. Do not guess. Do not monkey with without degree ing it. The cam "advance" is already built into the cam. |
| Edelbrock Performer Cam Timing Wrong | hotrodtodd1968 | Engine | 13 | 06-03-2012 09:43 AM |
| TBI 350 sum k1102 cam and edelbrock 5802 valve springs | Greenmonoluche350 | Engine | 3 | 05-30-2012 12:57 AM |
| Chevy 350 with 292 cam Total timing | ChevyMopar318250 | Engine | 63 | 10-13-2010 07:45 AM |
| 350 build. Need timing and edelbrock carb setup advice | artillerystevens | Engine | 11 | 09-14-2010 10:01 PM |
| Timing woes on SBC 350 with bigger cam. | Brawler | Engine | 5 | 09-07-2007 04:33 PM |
