Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - edelbrock 650 carb to rich
Old 07-25-2009, 12:37 AM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
what engine you got it on ? whats the specs on it ?
these carbs out of the box are usually jetted pretty rich
or its in need of repair due to age/worn parts
or there is something wrong with the engine
i dont think there is mucvh anyone do to help you through the internet especially without any info and not being able to see and hear the engine and carb
it could be bad/stuck/sunken float or stuck main needle or dirt in the carb
or too much fuel pressure
it could be many other things as well
i would try a known good carb and see how it does then,
if the engine is stock or close to it then i would put a good qjet on it due to them being very economical and good on fuel yet large in size, larger than most other carbs
