Originally Posted by hcompton
Yeah the electric choke kit is what you want. Just buy it bolt it on been there done that. You will need to use the manual choke everytime you start it cold even on hot days but olny for short time or plugs will foul easily on warm days. Its very annoying but the ele. Choke kit works so good you will consider it money well spent. Its sometimes easier to buy the performance tuned carb from edel in man. Choke then add the ele choke kit to make it drivable. Its often cheaper to buy the kit than retune the tame carb.
Thanks for the help, so with the electric choke, I would still need to use the manual pull out cable on cold starts?
