Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - edelbrock 750 on 350 having hesitation
Old 03-19-2012, 07:05 AM
dogwater dogwater is offline
Last journal entry: Still running strong
Change the position of the rod that pushs the pump to the last hole on the lever.That will make it squirt more fuel.Its going to run rich at idle with that size of carb.Problem is air flow is slow thru carb.You need a smaller carb. like a 600.I had this same problem,I could never make my 750 Eddy not run rich at idle.I barrowed a 600 eddy and most of the rich idle went away.You might try using your smaller pri. Jet and a fatter rod and if your vacuum is more than 14 in. use the strong spring, I think its the purple one.Air flow thru a 600 is faster.Your going to be like me I have a 750 Eddy that is almost new that I cant use.Also your efi pump is putting out around 60 or 80 psi when you only need 5 or 6 psi for your carb.The return will send that excess pressure back to the gas tank.
