Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - edelbrock 750 on 350 having hesitation
Old 03-19-2012, 09:14 AM
91chevyss's Avatar
91chevyss 91chevyss is offline
alright i try a different hole for the carb pump and ill look into a different regulator but want be able to get one right away. I also read somewhere that the torker intake could be some of the problem if not most. Is there a way to tell if its getting to much gas or not enough without any smoke coming out the exhaust? I think also i will change the jets back to the bigger ones that came with it which are .113 and .107 b/c i had .101 and .95 in the carb and i looked at chart earlier for the 1407 and didnt see an option for .95 or .101. and i never changed the rods when i done the jets could that be it. also a recap before i do any of this the engine bogs or hesitates from take off light throttle and once i apply more pedal it tends to lighten up. thanks everyone for the help
