Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - edelbrock 750 on 350 having hesitation
Old 03-20-2012, 09:11 PM
91chevyss's Avatar
91chevyss 91chevyss is offline
i thought that was right about the psi for fuel pump do you think thats too much to run with a dead head regulator at 5.5psi or should i look into a returm style. I also have a mechanical fuel pump to use if i need to just wasnt sure how to get the fuel from the tank. but before i get done with it ill be putting a fuel cell in the bed b/c the old one will scrub once i get the airbags on it. I dont have the money for the dual plane intake right now so ill have to make do with what i got but for now do you think ill be better off with or without the spacer. also the low end doesnt bother as much b/c of the 3:73. thanks again.
