Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - edelbrock 750 on 350 having hesitation
  #31 (permalink)
Old 04-01-2012, 08:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Hey freakin seuss.
Baseline the carb back to STOCK SETTINGS! Step up springs to suit the vacuum at idle and for tip in of the enrichment circuit (it's in the manual).
Set the timing correctly- be sure the total doesn't exceed 36 degrees.
Run it (you'll love it) and check the plugs to see what- if anything- needs to be done w/the carb settings.
