edelbrock air gap intake question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 09:46 AM
On an Edelbrock airgap intake is there a big advantage as to running a coolant line from the two water jacket bosses on the rear of the intake to the ones on front of the intake where the thermostat neck is? See this at the track yesterday and wondered if it would help my motor run any cooler? If so what size -AN line is recommended to use on this?
Old 04-06-2009, 09:58 AM
BackYardRacer
i dont think there would be to much to gain from that unless you have a 400 or to small of a raidiator but the only plus i see on that is for a 400
Old 04-06-2009, 10:38 PM
TorkMonster400's Avatar
uninteresting default message
Last journal entry: A couple of pics of the car
Wiki Edits: 4
No feedback yet,(the motor isn't in yet), but I will repost on how ot works for me. I bought a small kit from jegs.
Name:	coolant lines.JPG
Old 04-06-2009, 11:15 PM
people do not get the point in these water outlets are designed so you can tap i the water pump on the heater ports to them or the side of the block to them the whole point is to take water before it goes threw the block to the upper cylinder walls and head area were it gets the hottest and direct it straight to the upper head area to cool the hot spot in any motor
Old 04-07-2009, 12:30 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
If you run hoses from the rear of the intake to the water neck you are depriving the heads of coolant flow and they will run hotter. Water flows through the block from front to back, then through the heads from back to front.
Old 04-07-2009, 12:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would advise to use FB'88's schematic, above unless you take water from the side of the block.
With the set-up to plumb water from the water neck back to the intake, I don't see how there would be much flow either way.
It would seem that the pressures at both points would be about the same.
Anyone got any thoughts on this?
Old 04-07-2009, 02:25 PM
Wiki Edits: 4
ok so I have done this wrong then?
Old 04-07-2009, 07:43 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Seen most plumbed the way you have it, has a run on each side for each head. I also have this set up on a Weiand intake, if you have doughs I would just e mail eldo ,,, but what you are doing should be correct ..
not questioning what others have brought forward, just expressing what my own firsthand experience has been ..
Air Intake Design question dch921 Engine 6 11-09-2008 10:21 PM
Edelbrock Performer RPM Air Gap Manifolds Help leejoy Engine 14 10-22-2007 07:12 PM
Valve covers hit Air Gap Intake - new crate 350 VEGA 3503508.5 Engine 18 08-07-2007 10:11 AM
performer rpm air gap bracketeer Engine 24 05-29-2005 04:36 PM
Porting my RPM Air Gap lluciano77 Engine 13 03-09-2005 06:34 PM
