Edelbrock Aluminum intake install?
Edelbrock recommends using RTV in place of the end seals. What kind do you guys use?
I have used some kind of silicone adhesive on any intake manifold install on the end seals whether it cast-iron or aluminum and never had a problem. Small dabs of silicone will help hold the intake gasket in place also when you install the new manifold.
I just finished an install of an AirGap on my SBC. I used a 1/4 inch bead of UltraBlack in the front and back, I installed my Performer RPM the same way, and never had a problem.
Used the Permatex High temp,never leaked yet.Drive it daily.
Say that again Larry Seeing you in your journal,that sounds like the last thing you would say. |
I always used the gaskets with sealer until I had a rear seal leak resently on my S-10. I would suggest the silicone all the way. I like the red stuff, but any of it will work just fine. It does not get that hot anyhow.
Chris |
