Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Edelbrock Calibration Kit - will it work on an old Carter?
Old 03-02-2012, 05:00 PM
tjet tjet is offline
Hey thanks. I'm going to order the kit that's the same for the current Edelbrock 500 cfm [1404]
My primary carb is in the rear. Aparently, the carbs I have were made to run together. The rear carb [4758] has a choke and the normal vac ports. The front carb [4761] does not have a choke or any vac ports.
I'm currently building the fuel lines for it now. I'm going to use AGS NiCopp 3/8 line plumbed into a Canton Racing fuel filter [pic above]. I'm going to braze 2 edelbrock banjo fittings to the Nicopp line [limited clearance - see pic]
I just got my progressive linkage sorted out. Check out my return springs and mounts. I installed 2 s/s studs with spring pulls from McMaster-Carr
