-   -   edelbrock carb on 305 (http://www.hotrodders.com/forum/edelbrock-carb-305-a-219429.html)
ted200008 05-15-2012 02:34 PM
i have a 305 in a 84 el camino. i put a new intake and carb on. i think its a 650cfm carb. it runs great, but if i leave it sit for more than like 10 minutes, after driving it for awhile, and go to start it back up. it acts like its flooded and i get a lot of black carbon smoke out of the exhaust when it does finally fire up. is this too big of a carb or?? it runs great other than that. also it has a streight pipe going all the way back. i get a lot of black carbon smoke?? anyone have any suggestions?
cobalt327 05-15-2012 03:21 PM
If it has an electric choke you also might want to check to see that the choke's not closing (adjusted too rich) after a short cool-down. Not too likely, but it has happened.
ted200008 05-15-2012 08:38 PM
choke
the choke had vibrated way rich. i put it back and tightened it dont. it got rid of a lot of the black smoke and ran a lil better but it still has some trouble starting right up after it sits for more than 10 mins. im gonna try that carb spacer because i think it is getting too hot at the carb. but any other suggestions would be great too!!
John long 05-15-2012 08:43 PM
If your float is a little high to will exacerbate the problem........I have waited months to be able to use that word. :rolleyes: :mwink:
