Edelbrock carb choke - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2013, 05:19 PM
Can I turn my manual choke 750 carb to an electric choke carb??
Old 10-16-2013, 05:42 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I changed the name of your thread, simply saying "Edelbrock" doesn't catch many fish.
Semper Fi
Old 10-16-2013, 06:07 PM
techinspector1's Avatar
Wiki Edits: 326
Yeah, you can, but why would you want to? Manual chokes are cool 'cause you always know the position of the choke plate. I used to mount a microswitch on the linkage that would light a small light on the dash to remind me that the choke was pulled on.
The Following User Says Thank You to techinspector1 For This Useful Post:
Finley (10-16-2013)
Old 10-16-2013, 06:50 PM
I thought electric was better. I guess I will keep it manual then.
Old 10-16-2013, 11:11 PM
adam83's Avatar
Im pretty sure you can. I dont know what car or setup you have, but on my 1971 Charger, the black wire goes to ground, and the red wire I put on the hot side of the ballast resistor.
Old 10-17-2013, 06:44 AM
Irelands child's Avatar
Yes, you can easily change an Edelbrock Performer carb to electric choke. You get rid of that inflexible extra cable hanging out of the firewall with a single wire you can hide anywhere along with a ground back to the housing body. The 'kit' from Summit is (was?) about $45. My 'new' 600cfm 1405 has the mod though I actually 'stole' it from a well used 1406. It works fine though is fussy for initial set up (the carb IB needs to be followed for that setup):
Irelands child
Old 10-17-2013, 11:27 AM
lg1969's Avatar
Google "Tunnel Ram 406"
There is a conversion kit available.
Electric Choke Adjustment on Edelbrock 1406 4-BBL Carb horvath Engine 24 01-11-2011 07:49 PM
edelbrock choke solenoid ilcoalminer Engine 2 11-24-2009 04:57 PM
Edelbrock carb electric choke problems csilva84 Engine 3 10-06-2007 08:40 PM
Edelbrock Carb Choke wire problem rakundig Engine 2 01-25-2004 08:34 PM
Electric choke setup on Edelbrock carb JUSTINH Engine 2 04-07-2003 09:22 AM
