Edelbrock Carb Flooding - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2012, 09:59 AM
I've got an Edelbrock Performer carb on a SBC that randomly floods. The carb was almost new when I got it and after a few miles it would flood sometimes. I put a kit in it and it worked fine for 2000+ miles then started flooding again.
The fuel system is new with a filter before and after the pump, the pump is a stock mechanical. I don't think it's trash in the fuel and the floats are good.
What's up?
Old 09-15-2012, 10:26 AM
Banned
what is your fuel pressure? Did you replace your needles and seats? Are they damaged? Are your floats set properly?
Old 09-15-2012, 10:45 AM
Don't know what the fuel pressure is, it's a stock mechanical pump, never had a problem with presurre using a stock mechanical pump.
It has new needles and seats.
The floats are set correctly, it worked great for about 2000 miles before it started flooding again.
Old 09-15-2012, 11:01 AM
Banned
If the fuel pressure isn't too high (which it may be) then its either a poor seal at the needle and seat, or the floats are set improperly. That's it.
That is assuming that your problem is actually flooding though.
Old 09-15-2012, 11:24 AM
Have you ever seen a stock SBC mechanical pump with too much pressure?
regulator
my truck did this a few times before i got a good pressure regulator, and never sense. and for that matter, i had issues with cheap visual fuel filters letting stuff get into the seats and causing issues, not even shutting my fuel pump off and running the truck out of gas helped that issue which is why i gatta use a good filter.... and i live in silt ville lol =]
Old 09-15-2012, 01:01 PM
Those AFB style carbs are very sensitive to pressure. They need to run around 4-5.5 psi, which is under what most mechanical pumps produce. You need a good regulator, preferably one with a return line to keep pressure steady.
Old 09-15-2012, 01:31 PM
This is my first AFB style carb, usually run a Holley and never had this problem before. I'll get a regulator with gauge and see if it helps. It's flooding just like before I replaced the needles and seats, it must be the pressure is right on the limits.
Old 09-15-2012, 03:20 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Ihad a similar issue with two Edelbrocks on a tunnel ram and big cam, when I got it the idle mix screws were so far out of adjustment the guy had the idle adjustment screw set so the primary butterflies were slightly open to keep it running, allowing fuel to drip into the venturies, easy fix.
Semper Fi
Old 09-15-2012, 03:35 PM
Trucknut's Avatar
I'm running Edlebrocks on a 1967 GTO 400 and a 1965 Chevelle 283. Both have mechanical fuel pumps. Never had a problem....uh....yet?
Old 09-17-2012, 06:18 PM
Checked the pressure and it was over 9 psi, put a regulator on it and set it to 5.5 Edelbrocks recommended setting, it stopped flooding.
Old 09-18-2012, 12:42 PM
Glad to hear it!
Edelbrock Severe Flooding RotorHead Engine 5 07-24-2011 02:26 PM
Edelbrock 1406 Flooding? Eric64 Engine 7 12-24-2010 02:18 PM
Edelbrock 600 flooding American Muscle Engine 17 09-04-2009 09:11 AM
Edelbrock carb flooding bad breemijoe Engine 4 02-21-2008 05:46 PM
Carb Flooding Don proper Engine 4 08-21-2006 06:36 AM
