edelbrock carb guru's help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2007, 06:07 PM
406 ss monte's Avatar
eat a beaver, save a tree
i bought a used edelbrock 600 & put it on my truck. it runs fine as long as it's not idling. i can screw the idle mixture screw all the way in on the passenger side & it doesn't change the rpm of the engine at all, i can take it out of the carb & it doesn't change anything. the other idle mixture screw works as it should. it also has a little drip on one of the front venturi. i'm not sure what causes that (i think a dirty needle & seat or metering rod?). i used to be good with these edelbrock carbs, but i've been on holleys for a good while now & just about forgotten every thing i new about edelbrock carbs. i'm going to put in a rebuild kit, but what else should i look for? thanks for your help.
Old 05-28-2007, 07:06 PM
Take both idle mixture screws out and use a good carb spray cleaner with a tube type nozzle and spray it in where you took the idle screws out. Now follow up with a blast air in the same place with a rubber tipped nozzle. Then clean the idle mixture screw tapers real good then then reinstall. bottom them lightly and back out about 3 turns. It should idle better, then adjust accordingly. The dripping venturi may take care of it self after you do this. If not, probably a float needle and seat or the floats are set to high. Hope this helps you out
gcrmcc
Old 05-28-2007, 07:35 PM
that's what i was thinking of doing. i just wasn't sure if compressed air would hurt anything or not. thanks
Old 05-28-2007, 09:44 PM
No, it won't hurt the carb, I've done it many times over the years on used AFB's and Edlebrocks that have been sitting for a long time. Let us know how it works out. If it dosen't, I have other things you can try.
gcrmcc
Old 06-25-2007, 07:08 PM
just here to give you the results.
i took the top off the carb & it was full of rust & all kinds of trash. cleaned it out & it still had a drip out of the passenger venturi. i put my hand over the chock horn & smothered it with the engine turning about 5,000 rpm. i did thats a few times & the drip stopped.
i blew out the idle passages like you said with carb cleaner & compressed air & it took care of the other problem i was having.
i just got my air compressor back up & running this weekend, thats why it took me so long to post back.
Old 06-25-2007, 07:45 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I was Taught, when one or both Idle screws Have no effect on the mixture, It's time for a full rebuild!
It usually ment the Mixture Circuits were full of alien lifeforms and other Mung and crud, Or the Screws Had been bottomed out so tightly they scarred the taper against the throttle Body and now leak..
First place I'd start is pull it down and boil it out for a couple of hours, Neutralize it, Air dry it good, then install a new kit..
That usually sets it right..(if you follow the destructions <--misspell, but I like it , so it stays..) And set the levels and linkages Correctly..
Then again, I'm a Q~jet guy..Done only a FEW Elde's and Holley's ..but of the ones I have..this worked fine.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Edelbrock 600 CFM Carb help Toy71Camaro Engine 17 11-16-2010 08:01 PM
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 09:19 PM
Tuning and identifying a edelbrock carb junkyardjeff Engine 2 01-02-2006 06:23 PM
More Edelbrock carb trouble 85CHEVY Engine 2 08-16-2005 05:05 AM
priming a new edelbrock carb crshrmn3 Engine 8 10-29-2002 05:04 PM
