Edelbrock Carb not shifting tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2011, 01:49 PM
I have a 87 chevy caprice 305 engine with 1406 edelbrock carb that has electric choke. i hooked the vacuum lines up to the carb from the intake manifold. but the tranny doesnt have a vacuum modulator had electric down shift from rochester carb. How do i get my tranny shiftin properly??????
Old 11-11-2011, 03:13 PM
tnsmith10's Avatar
when will it rain???
that was not an electric kick down for the trans. more than likely it is the idle solenoid for the a/c.
that car should have either a 200-4r or a 700r4 trans in it and stting the tv cable is critical and, with the carb you installed, it is going to need a tv geometry cable corrector and the tv reset for proper operation.
the tv cable needs to be pulled tight when the carb is @ WOT.
Old 11-13-2011, 02:10 PM
327NUT's Avatar
What tnsmith said....the TV cable is more than critical to get set properly BEFORE you drive the car or you will be rebuilding the trans. You can find a very informative article on the set up at www.bowtieoverdrives.com
Old 11-13-2011, 06:36 PM
JeffB's Avatar
Here is a good picture of it and where to get one. http://www.oregonperformancetransmis...y_Code=700R4HP
Tranny shifting to fast butch1967 Transmission - Rearend 8 04-25-2007 11:13 PM
700r4 tranny not shifting out of 1st dmd02769 Transmission - Rearend 3 09-21-2006 10:45 PM
350 turbo tranny not shifting to 3rd actionphilson Transmission - Rearend 1 11-17-2005 07:22 PM
C-6 tranny not shifting in 3rd 66 T-Bird Transmission - Rearend 1 09-13-2005 09:22 PM
Tranny Shifting dollybud Transmission - Rearend 1 08-12-2003 09:37 AM
