Edelbrock carb ... spring etc recommendation? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2003, 06:36 PM
Dooce's Avatar
Post Edelbrock carb ... spring etc recommendation?
What carb jets, rod, springs, accel pump, or other simple mods would you recommend for this:
- crate sbc HO350 (vortec heads, rated 330hp)
- Edelbrock 1406 600cfm carb, Performer intake, no spacer
- at 4500 feet altitude the car runs better at 1-1/2 stages lean - which means I'm running 1426 main jets & 1456 rods, & oem springs
- accel pump lever set to max
- ~11-2 degree ignition advance
- 700r4 trans
- roadster weight ~2300 lbs
- it's running fine, but seems to lack punch
Thanks!
Old 06-02-2003, 07:54 PM
Dooce's Avatar
Post
bump
Old 06-03-2003, 04:45 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Knowledge Base
Luv the smell of NITRO in the morning.
Old 06-03-2003, 07:02 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Buy a tuning book.
