Edelbrock Carb Won't Idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2009, 10:21 AM
Sinister's Avatar
Swapped my intake and carb on a 350. Performer EPS and a remanufactured Edelbrock 1406. Doesn't want to idle at all. Have to put the pedal to the floor to get it to run at all. Doesn't rev up when I do this. Runs real rough. Float adjustment?
Old 12-20-2009, 11:06 AM
XNTRCI-T's Avatar
AKA Lee in KC
The floats need to be reset right out of the box. Very sensitive to shock loads during shipping. Also, check your fuel pressure. These carbs don't like more than about 5# of pressure.
Old 12-20-2009, 11:09 AM
link to the complete carb manual:
http://www.edelbrock.com/automotive_...ers_manual.pdf
troubleshooting chart is toward the back (page 20+ something???)...
check off all those possibles and come back if not solved...
Old 12-20-2009, 11:19 AM
Sinister's Avatar
Thanks for the replies. Have the manual, going to go through it and see what's up.
Old 12-20-2009, 12:05 PM
Irelands child's Avatar
....also very sensitive to dirt.
Irelands child
Old 12-20-2009, 12:08 PM
not explained real clear in the manual:
the idle circuit is totally independent of the others and the idle circuit air bleed is thru those 2 small brass tubes (exposed to dirt) (next to the rods covers) sticking out the top....
if they are clogged it won't idle....
almost always,,,, zapping them with a shot of spray choke/carb cleaner (or wd40 whatever) using the extension tube taped to the can will clear them....
won't hurt/might cure it/try that first...
Old 12-20-2009, 02:08 PM
Sinister's Avatar
Thanks for all the replies. Adjusted the choke and revved it up, must have blown some dirt out of the idle circuit. Running decent for now, will tune it up tomorrow. Thanks again.
Old 12-21-2009, 06:09 AM
your welcome....
sometimes just different wording of a explaination (for anything) versus the manual really helps....
Edie carbs have been covered many many times in detail on this board so for a quicker answer and time shortcut try using the search function...
LOL,,,"choke????",,,mine is pinned to stay open with a zip tie,,,it's the one (primative) original oem linkage design function I do wish they had improved...
I don't need it here in FL but it is wise to use one to raise the block temp ASAP for less wall wear....
happy holidays
red
How do I know if my Edelbrock Carb is leaking air? jpd37 Engine 23 01-24-2009 06:01 PM
Edelbrock 750 tuning GCD1962 Engine 34 04-16-2008 06:03 PM
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 08:02 AM
idle o n a 400 small block with edelbrock carb bigcam Introduce Yourself 2 05-08-2006 09:17 PM
Holley 650 / Edelbrock performer combo Andy in SD Engine 4 11-07-2005 09:25 AM
