edelbrock carbs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2002, 11:35 PM
Question edelbrock carbs
I'm having problems with my edelbrock performer carb. I have it on a chevy 350, it has electric choke. The problem is that only 2 of the barrels are opening and the secondary ones never open up. Any help appreciated, thanks.
Old 09-01-2002, 06:36 PM
HotRodF100's Avatar
Post
Try www.edelbrock.com/automotive/index.html This website has breakdowns, FAQs, and setup info for Performer carbs. I think that you will find anything that you need here. My Performer carb has a mechanical linkage that opens the secondaries with a flapper that opens when the vacuum draws it open. Did you maybe have the top off of the carb to adjust the floats and forget to put a rod back on? Do you have your throttle set up to pull 100%? There are different holes and there is usually an adjustment on the throttle linkage that would cause the problem. I would disconnect the throttle and see if you can manually open it 100%
[ September 01, 2002: Message edited by: HotRodF100 ]</p>
