Edelbrock Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2007, 03:47 PM
MI2600's Avatar
Member# 3287
I have a Edelbrock 1407 that is a manual choke carb. The choke housing has a vacuum port. On the carb there is a brass plug where the vacuum port would normally make contact with the body.
I want to convert to an electric choke, but I was wondering if the port behind the brass plug is normally functional, i.e. drilled. I don't want to pull the plug and find the passage isn't there.
Anyone?
Old 07-23-2007, 09:11 PM
MI2600's Avatar
Member# 3287
We must have someone with Edelbrock expertise.
Old 07-23-2007, 09:47 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I've never done it but I found this instruction sheet. I hope it helps.
http://static.summitracing.com/globa...-1478_inst.pdf
Old 07-23-2007, 09:54 PM
MI2600's Avatar
Member# 3287
Thanks, Blazin. That's what I needed.
Old 07-23-2007, 10:17 PM
Blazin72's Avatar
Wiki Edits: 19
No problem.
Edelbrock Performer head #60909 Houman SS '70 Engine 4 01-20-2009 09:56 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Edelbrock Pro-Flo Problems Unkie Engine 11 05-22-2007 05:20 PM
Big thanks to Edelbrock crew cboy Hotrodders' Lounge 12 07-19-2006 12:07 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
