Edelbrock E-Tec Heads vs- Edelbrock Rpm`s. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2004, 09:55 PM
I`ve heard from many that the E-Tec cylinder head by Edelbrock is better than the RPM head. Enough said. I have a set of RPM Heads ( 64 cc ) and the engine is dis-assembled. Before I put it back together, is there anything that I can do to my RPM`s to make them better? example-porting?
355 chevy, 9:7.1 CR, rpm intake, 750 carb, balanced.
Old 10-22-2004, 08:18 AM
coldknock's Avatar
The E-Tec heads work a little better because the slightly raised intake ports.
A five angle valve job for the RPM heads will help some. If the shop you choose has the tooling to do a bowl cut with the valve job, get it done. You'll get more for your dollars there than you will with a die grinder and a carbide cutter.
Make sure to use a reputable machinist, ask for customer references.
Larry
Old 10-22-2004, 11:19 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I was involved in a customers engine for circle track applications and found the edelbrock heads had chamber centerlines all over the place. Seems the quality was low. I don't know if this is indicative of the overall QC though.
Old 10-26-2004, 07:39 PM
acr acr is offline
According to flow tests by Chevy High Performance & others these heads flow almost identical numbers. But if you decde to sell your Performer RPM's please let me know first!!
Johnson, did you send those heads back to E-brock? I understand they are good about replacing defective product.
