Edelbrock a/f moniter any good? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2009, 11:52 PM
I was wondering if anyone has had any luck with the edelbrock air/fuel ratio moniter (part # 6593)? I will be using it on a carb'd sbc 327 far from stock. Is there anything that i should know before buying it? Any suggestions to a similar but better one?
thanks, Josh
Old 09-23-2009, 05:32 AM
bentwings's Avatar
bentwings
I have this one
http://www.summitracing.com/parts/SU...5/?image=large
which is really this set.
http://www.innovatemotorsports.com/x...cat=262&page=1
Mine works very well. It responds very quickly and was dead on compared to the local dyno shop.
Innovate has an active forum too so you can ask questions.
Old 09-23-2009, 11:33 PM
ericnova72's Avatar
More for Less Racer
The Edelbrock set-up is a narrow band controller and really won't give you much info. Check here for wide band controllers and info for do-it-yourselfers. www.14point7.com
Edelbrock Pro-Flo Problems Unkie Engine 11 05-22-2007 06:20 PM
Big thanks to Edelbrock crew cboy Hotrodders' Lounge 12 07-19-2006 01:07 PM
Edelbrock Performer IAS shocks any good? 2506CYL Suspension - Brakes - Steering 4 09-23-2003 11:19 AM
350 and good gas milage and a combo HELP changer01 Engine 7 09-23-2003 12:05 AM
Edelbrock carb tuning Oldsmoblily Engine 4 06-12-2002 07:44 PM
