what is your gear ratio and tire diameter also automatic or stick if automatic are you changing or does it have a higher then stock stall?
what carb will you run?
Not sure what a Stock 1974 Nova gear ratio is. It is though an Automatic. Haven't decided on the tires yet. I need to get this thing moving first and then some body work and paint. I may have to get a new rearend too. The Nova was hit on the drivers side pretty much smack dab center on the rear tire area.
i don't think you would want a cam thats rpm range is 3000-6000,you should figure out what your going to use for a gear and tire to have an idea of the rpm range that you would be running most then pick a cam.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
