Edelbrock Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2006, 04:42 PM
Edelbrock Heads
Does anyone have any experience with the Edelbrock aluminum heads for big block chevy? They say in the catalog that consideration needs to be taken as an open chamber style piston can't be used with those heads because of the spark plug location. I am wondering if a closed chamber style piston will work.
Old 01-01-2006, 05:19 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Which model head? I use the performer RPM heads by the dozens.
Old 01-01-2006, 06:48 PM
Yeah but I think there is a multitude of other factors to consider regarding piston design. Infomaniac can probably help sort it out for you better then me.
I will say that I used a set of Jr's heads on a 496 bbc blower motor build up for a friend and don't think I have ever seen a nicer looking cast aluminum head. The motor was destined for a show car so I was pleasantly surprised. I think if your going for looks, you cant beat Edlebrocks heads.
Old 01-02-2006, 10:13 AM
good looks isn't what I'm after.....lol........It is the Victor Jr ported version of the Performer RPM.
Old 01-02-2006, 12:22 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I've got a new set of Edelbrock "Rovals" for my '35-haven't used 'em yet, but I think they are 110cc chambers-aren't you looking for the square ports (RPM range 4500 and above)?
Craig
Old 01-02-2006, 12:24 PM
Infomaniac's Avatar
The piston mfg can tell you what heads they are compatible with.
Old 01-02-2006, 04:02 PM
The Chapman ported Victor Jr is available in rectangular or oval ports w/ 112 cc chambers which like the 110cc are "semi-open chambers". TRW has a piston for my bore but it is closed chamber design with a .474 dome which as far as I can tell will give about 10.5:1 with the 112cc chamber. Just wanting to know what type of piston others have used with the performer heads.
Old 01-02-2006, 04:57 PM
BOBCRMAN@aol.com's Avatar
I have built several different combos with the Performer RPM head. Each one needed "massaging" of the piston dome to clear the chamber. SRP's open chamber needs the least cutting. TRW/Speed Pro/Manley pistons, 2307-2308 won't fit without MAJOR re-profiling of the dome. The closed chamber pistons would probably need cutting around the outer surfaces of the dome.
Old 01-03-2006, 11:13 AM
I am checking with SRP now. Thanks for ya'lls help! The TRW part numbers listed above show on flatlander that dome machining is req'd.
Old 01-03-2006, 11:48 AM
engineczar's Avatar
Built a BBC with the Edelbrock RPM heads and 12.5:1 SRP pistons (pn203433) last year for a customer. With the stock 119cc chambers the pistons required no work to fit.
Old 01-03-2006, 04:55 PM
Heres where things get tricky for me. I have a 402 with 4.155 bore. The only piston available that I can find is with a closed chamber dome. I am looking at the Victor Jr. CNC version with a 112cc chamber to keep compression up. I am waiting to hear back from SRP on their 402 closed chamber piston..............but I can get a custom set made for $685 to any specs and I'm guessing 8 SRPs are gonna cost more than that so.........the saga continues.
olds 403? Meka Engine 15 09-11-2005 01:48 PM
TBI Heads on older motor exmurdoc Engine 1 07-08-2005 05:21 PM
Heads novatech Engine 10 01-17-2004 01:27 PM
AFR Heads DTL504 Engine 9 12-09-2003 02:55 PM
bowtie heads for sbc Eddie Baker Engine 3 11-08-2003 11:02 PM
