Edelbrock Idle Mix Screws reset position? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2009, 08:59 PM
greenmoonshine's Avatar
have a pheasant plucking day
Does anybody have a clew what the factory setting(position)are for these 2 screws? I cannot find it anywhere and I have the owners manual......all it tells is how to set them,but not what the stock position of them are and by position what i mean is there factory base line setting(if screwed all the way in,how many turns back out to factory specs).Got the carb off a buddy of mine and its all JACKED up...any ideas would be helpful,its a PERFORMER 1406(600cfm)carb
Thanks
GM
Old 02-05-2009, 09:38 PM
Tics60's Avatar
1960 BelAir w/66 427 bbc 650hp
AFB is 1 to 1 1/2 max which should cover the edel one as well. Both my AFB are at 1 1/4 on my tunnel ram.
Old 02-05-2009, 10:04 PM
So thats 1 1/2 FULL turns out max....and that should get me in the ballpark,
O.K., I will give it a try in the mornin thats if is not 16 deg. out again
Thanks
Old 02-05-2009, 10:36 PM
Tics60's Avatar
yes - turn until they are closed or in all the way, do not over tighten be nice to the little screw , then turn out 1 and 1/4 turns to start. Should be dam close depending on your motor. My SBC 350 is 1 1/4 Dad's olds is about 1 1/3 so that should get you running.
Old 02-06-2009, 12:20 AM
Thanks a mill.... ill be sure to be easy on the lill guys ,the last thing I nead is to strip one of them out .... is it possable to flood your carb easier if your not using a fuel filter? this might be a dumb question but wouldnt a fuel filter act more like a small restriction,almost like a set regulator...and without that in place cause fuel to get forced into carb to quickley =ing in flooding?
Old 02-06-2009, 06:20 AM
bondo's Avatar
Nope,....
But,.. Running Without a filter Will introduce a pile of $h!t into the carb....
Old 02-06-2009, 10:07 AM
Tics60's Avatar
Originally Posted by bondo
Nope,....
I'll add .. BIG Pile! 5.5 =6PSI on the fuel pressure. More and fuel will pass the seats which can cause flooding.
Float set to high = flooding
bad seats = flooding
to high fuel pressure = flooding
bad body gasket = flooding
Before running it may sure the area is dry in the carb and get a good light, Pull the coil wire or whatever so it won't fire. Either use a remote button or a buddy whose still sober after sucking down all yor PBR have them spin the motor over WITHOUT touching the throttle and look into the carb. Repeat a few times.
Do you see fuel spray in there? A puddle forming in the back secondaries?
No?? Your seats and such are fine
Yes?? Your seats and or all the above are bad or need adjusting.
Floats are easy - 7/16 drill bit dead center of the float with the unit upside down.
Seats you can gently clean sometimes with hot soapy water.
gastket - make or buy a new one.
Now go buy a 5 dollar filter!!!!
Old 02-06-2009, 08:47 PM
Wow....I must have known that was cummin....After work today I went and bought a filter but it wasnt $5 it was a whopping 10 bones....got one of dem fancy MR G clear glass ones, now to see if i can try and not brake it....I wasnt being cheap,I was just trying the carb out to see if I was going to keep it,thats all.......Im converting My monte SS over from comp. controlled to NON...now im just working out the bugs...thank for the input
GM
Old 02-10-2009, 01:48 AM
Got the IMS set out at 1 turn and it runs better than with the ccc but when I bump the throttle it backfires up threw the carb but not bad enough to stall it.....it looks like a small geyser erupting......and idles rough,I havent checked the timing yet with a light,just by sound....I have read that 80% of the time the cause is timing,10% could be to lean and the other 10% is reserved advance timing problems like vacuum adv. diaphragm or maybe mechanical adv. springs weak or worn......I recurved the timing so its new......im betting its the timing.
GM
350 Chevy off Idle Issues 84Caprice57 Engine 36 02-20-2011 04:43 PM
vacuum gauge readings GMR Engine 11 08-25-2008 12:03 PM
Help tuning 383 for street use strokey Engine 34 04-11-2008 05:51 PM
? re: idle mix adjustment on 2150 2V carb cboy Engine 6 07-19-2005 05:31 PM
edelbrock idle adj. screws onecoomofo Engine 4 04-14-2004 04:17 PM
