Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Edelbrock Intake Manifold Install
Old 01-16-2013, 05:08 PM
64Joker's Avatar
64Joker 64Joker is offline
64Joker
Make: Chevrolet
Model: Impala SS
Year: 1964
Engine: 327 cui
This is my first attempt at swapping out a intake manifold and I need a little direction.
Problem: Old Edelbrock intake (12 years) cracked.
Project:
Attempting to replace intake manifold with new Edelbrock intake manifold model 27013.
OLD INTAKE:
-When removing the old intake, the first thing I noticed was that the old intake has 6 water passages (the new intake has 4).
-The previous owner, for whatever reason, blocked the 2 end passages (near firewall) with some sort of cement filler within the intake itself.
Someone advised me that my heads were "camel hump", is there a difference between a "stock" intake and "camel hump" as far as the number of water passages (6 versus 4).
-The previous owner also did NOT remove the gasket center holes for the
middle 2 water passages, thus it appears the old intake was only circulating coolant via 2 passages (back 2 blocked, middle 2 gasket blocked).
NEW INTAKE:
In comparing the old intake with the new, the new one has 4 coolant passages (the back 2 were machined closed by Edelbrock), I'm guessing that was either for performance improvement or stock versus camel hump head configuration.
Also, Edelbrock included 4 thin metal plates with the new intake, how are those used and do I need to use them? Note: The new intake gasket has cutouts for the 2 center passages, you can't see them in the pic.
So, is it okay to go forward with new intake install after clean-up of heads/ports and suggested configuration?
Note: See attached pics of intakes, gaskets, heads, engine, etc.
ID:	70641   Click image for larger version
Name:	intake gaskets.jpg
ID:	70642   Click image for larger version
ID:	70643   Click image for larger version
ID:	70644   Click image for larger version
