Edelbrock Marine Heads-BE AWARE
Anyone buying Edelbrock Marine Heads please be aware that the valve guide size is 11/32 instead of the standard 3/8, you would think that buing a marine cam kit and marine heads would all be the same size but its a good thing i noticed this before initial start up or I could have had a major catastrophe! They at least could have put a notification in the box or something.
I am missing something here, what does the valve guide size have to do with the cam ? Please make me smarter..
I have had a couple of incidents this year on aftermkt BBC heads and customers buying the accessories.
One was a complete Comp Cams valve train kit. Springs, retainers, seals, etc. along with cam and lifters. Owner installed kit parts on his aftermkt heads. 11/32 v-stems.. 3/8 10 deg. valve keepers in set.. Motor lasted till he decided to "make a pass". Dropped several valves destroyed engine.. Second incident. A well known engine builder installed another Comp Cams v-train kit. Owner noticed (after two weeks of breakin) that one of the valve locks had jumped up about 1/16" and was not looking good. Brought it to me. same deal 3/8" 10 deg. locks on 11/32" valve stems.. Of course the builder claimed "defective locks"... |
Ok cam, lifters and valve train kit .. now that makes total sense. I am used to buying cam and lifters , springs from another manufacture. Was not thinking about the possibility of a soup to nuts cam kit ... That clears the head, all better now.
The "standard" SBC valve stem diameter is 11/32", w/some trucks getting 3/8" exhaust valves. No clue on marine engines, though I thought they were the same, at least for the most part- like over the road vehicles...
So you are saying the cam kit supplied you with 3/8" keepers and locks? Yet the heads were 11/32"??
the cam kit contains everything it was a comp k kit, thank god i dident drop a valve
Correct Cobalt327. These are kits for Big Block Chevies...10 degree locks.. 7 deg locks would show up quite a bit if mis matched..
Evidently this has happened to a few others,, by the PMs I get.. I know Comp will tell you that it is the fault of the installer for not checking sizes.. |
The SBC with the 3/8 stem, sodium-filled exhaust valves used standard keepers and retainers. The valves necked down at the top, for some unknown reason. Somewhere I have a box of them as we always saved them from cracked heads due to their cost. And, the stems rarely had excessive wear like many standard valves.
I build my heads my self, from now on im deff checking out the stem size. what would be the advantage of having a 11/32 stem size vs a 3/8? You would think that being a COMPLEATE marine cam kit, and being Marine heads they would at least make them compatable with each other, I realize they are not the same company, but at least put a notification or something.
I believe the thought behind the larger 3/8" stem is for durability. They're also used in truck applications- any place where running at the torque peak is likely to be sustained.
The "down side" to a 3/8" valve stem is that it impedes flow to some degree, and is heavier overall. Even aftermarket BBC heads can be had w/11/32" stemmed valves. So, were the seals, retainers and locks from the "K" kit 3/8"? |
yup everything in the k kit was 3/8
| Edelbrock rpm heads | monster mouse | Engine | 1 | 02-04-2010 11:59 PM |
| Edelbrock alu heads advice | jeepers creepers | Engine | 3 | 12-26-2008 02:14 AM |
| Edelbrock etec alum heads | sanman | Engine | 2 | 01-17-2008 06:41 AM |
| Edelbrock Performer Rpm Heads | Silver00V6 | Engine | 2 | 06-22-2006 06:12 AM |
| BBC heads | 65chevymike | Engine | 8 | 04-21-2004 02:25 PM |
