Edelbrock Performer / Holley Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2003, 09:00 PM
western star's Avatar
I have a Performer for a sbc. The secondarys on the intake are larger then the primarys. I guess you would call it a spread bore. I want to install a 670 Holley Avenger to it. The Holley I believe is a square bore. Do I have to use an adapter and if I don't.....what happens?
Old 11-30-2003, 09:23 AM
Tazz
Edelbrock to Holley change
I think it depends on your intake, some are setup for both carb bases. If you end up using an adapter plate be careful not to drop a carb mounting bolt down into the intake, be very careful. Put nuts on the bolts sticking up out of the base before trying to install the base.
Todd
Rat Rods Rule!
Old 12-01-2003, 01:41 AM
Performer intake
Its possible to just put gaskets on the performer and get by but to play it safe and avoid vacuum leaks : there is a bout a quarter inch thick plate that you should put on this intake.It is metal and it doesnt come in the manifold box,and the guys here at the aut o-parts didnt even know what I was talking about. I found 1 at Oriellys $ 7 , believe it was a Holley product .
Old 12-05-2003, 06:15 PM
bullheimer's Avatar
NEVER use credit cards!
i asked the same question at a pontiac site and pretty much got told i could put the square bore right on it since it's drilled for those mounting holes. that 1/4 plate doesnt sound like a bad idea tho. i have used adapter plates the other way around and the mr. gasket one was a p.o.s. it wouldnt allow the butterflys to open all the way until i ground the dog-poo out of the openings. if you put the carb on the intake just check to make sure it can open up to wot all the way by pushing them open with pencil or something before you put it on the car
Old 12-06-2003, 12:56 AM
lluciano77's Avatar
Edelbrock makes a 1/8" thick plate for eliminating the vacuum leaks which are common when bolting a squarebore carb on a spreadbore manifold.
Old 12-06-2003, 11:48 PM
Thats the one ;thin metal, open plenum, eliminates chance of vacuum leak and its cheap. Not an aluminum adapter, no nuts and bolts to fall in because it just slides over existing studs on intake. What gets me is they dont come with the new intakes and they dont mention anything about using on intake. On intakes Ive used there is only about 1 -16th seal on back bottom of carb and intake if your lucky.
Old 12-07-2003, 12:56 AM
I've been told to use the thick (3/16th) gasket with the gromets in it and it works just fine.
