edelbrock performer intake question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2008, 10:46 PM
Casperdude898's Avatar
on this intake there is 2 screw holes in each corner and someone told me you can bolt both a spreadbore and squarebore carb on there is this true? i thought you had to have an adapter to put a square bore carb on that intake. ???? which is true
Old 05-30-2008, 10:51 PM
SSedan64's Avatar
Yes it will take the Holley Squarebore pattern or Quadrajet spreadbore pattern. The 2 different carbs have different bolt patterns that's why 2 holes in each corner. You still have to have some type of adapter plate to cover & seal the larger rear bore area though.
Old 08-11-2008, 07:36 PM
You can run a square bore, no adaptor plate needed. You have to find the right gasket though. Not sure if a square gasket will work. I used a ratty old Q-Jet insulator gasket that I tried to replace but they're not all the same... Or just get gasket material and cut it on the intake.
Edelbrock Aluminum intake King Kong Engine 6 01-03-2008 07:29 PM
need info on Edelbrock rpm performer and.. ryork Engine 4 09-22-2007 04:23 AM
Intake & Carb question Houman SS '70 Engine 31 03-24-2005 05:05 PM
Stock intake vs. modern Edelbrock petiepye Engine 11 02-14-2005 12:08 PM
Question for Edelbrock Performer fuel pump owners HotRodF100 Engine 1 07-20-2002 04:47 PM
