Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-14-2003, 03:43 PM
nova69 nova69 is offline
Post Edelbrock Performer - more top end
Are there any tricks out there to squeeze more top end out of a regular Performer intake manifold? Literature has the Performer producing power through the 5000 rpm range and the Performer RPM to 6500.
Old 02-14-2003, 05:31 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Is There Anybody Out There?
Post re: Edelbrock Performer - more top end
a open spacer will give it more high end, but at a loss at low end power. or you can remove a notch about a inch long and about a inch deep from the plenum devider which will give it a little more top end at no low end loss, some guys remove the whole plenum devider which is a mistake if it`s not a high revver.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
