edelbrock performer package hp increase? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2010, 05:26 AM
jls4speed's Avatar
my motor is a 79 350 with an edelbrock performer intake, cam, and 600 cfm. i added roller tip rockers msd streetfire ignition witth an accel super coil, lighter dist. springs, ACCEL 8mm wires and headers. the exhaust isthe common y pipe setup that splits off to dual pipes on the 80's monte carlo ss. its a 1985 monte. without a dyno run and the timing set to 14 what kind of power do you guys thing this motor is making. i ran the block numbers and heads. the heads are 97cc and the block is a two bolt main setup that said it came with anywhere from 200 to 375 hp stock.
Old 09-27-2010, 11:03 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What make is the engine? If it's a Chebby, the heads are closer to 76cc if they're original.
You might be making somewhere around 300 HP. Or not.
You say timing is at 14°- this is the initial timing, I take it? You should use about 36° total timing w/o adding the vacuum advance. Unless you modify the distributor, set the total to 36° and let the initial fall wherever it falls, unless it is too much initial timing to allow hot starts.
If that's the case (hard starting due to too much initial w/the total at 36°), you'll need to modify the distributor to add to the mechanical advance available or add an ignition interrupter.
On the other hand, if this drops the initial too low, you'll need to limit the mechanical advance allowed by the distributor, or use manifold vacuum for the vacuum advance so there's additional advance available at idle.
Old 09-27-2010, 03:05 PM
jls4speed's Avatar
sorry they are 64 cc heads. i have another question. on my timing marks it goes up to 16 initial on the retarded side and 8 initial on the advance side. what do i do just guesstimate here or something to get 14? ive been having reman starter issues with grinding but have had motor running to break in new cam. ive4 bought 3 different starters, shimmed em aevery which way, bought new bolts, i cant get them to catch right. ive put so many starters in gm's n never had such problems.
Old 09-27-2010, 04:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The tab should have more degrees shown on the BTDC side (CCW from 0) than the ATDC side of "0" (TDC).
On the tab below, "0" is just to the Left of the "A" in "AFTER". Each division is 2°.
MAKE A TIMING TAPE to see what the total timing is, or to extend the tab so you can read further out than the tab goes.
DETERMINING TDC will allow you to be sure the timing tab and damper are correct for TDC.
About all that is left is a bad flex plate, I'd say.
Old 09-27-2010, 08:33 PM
jls4speed's Avatar
brand new flex plate. im still not understanding the timing thing. i can build a motor to run mint with full confidence but when it comes to math like this im not confident. its jibberish. i have that same tab for timing like the pic. ive always timed by ear. being a new motor i want it done with a light. so when i plug the advance i should put the mark on zero and turn dist clockwise and it shoul move to the 6 mark then 8 mark and so on till 14 right. if i get timing tape i put the zero on the tape with the mark on the balancer? then turn it to 14 on the btdc side? idk. i have a hard time taking info like this from paper to doing it for real. i have a much easier time doin sht hands on if u know what i mean.
Old 09-27-2010, 10:29 PM
The performer package is awesome on a torque build with 1800-1900 stall. For instance a 305 head 350/th350 with EPS intake and 3.08 8.5" rear 235/70/15s laid down 206 rwhp. Stock exhaust manifolds with 2.25" turbo muffler true duals. Tuning required a long curve 38 degress total, 18 initail and 2o in at 3200. 10 in the vac can at manifold vacuum ***. Cheapo ebay HEI controlling it all. Carb was a M4M Q jet dual pump G hanger , DR secondaries.
Forced downshift at WOT is intense. Tires burn off the OEM rally's. Smooth cruise.
Not a corvette, but it is a hard pulling vehicle build.
The RPM build was not so good for a road car. Poor actually, but dragster fast.
Old 09-27-2010, 10:31 PM
you can not say *** ?
How about nipple ?
Old 09-28-2010, 12:03 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
How about nipple ?
I suppose you could use the word titt and then put (sic) after it. (sic) is used when the writer knows the spelling is bogus, but wants to convey the writing just as it was presented by the original writer, or in this case in order to try to outwit the profanity machine. Another example might be like the word "perfect". If it were spelled wrongly, as "perfekt" for example, and you were repeating it for someone else, you would use the mis-spelled example and use (sic) after it, telling the reader that you know better.
http://en.wikipedia.org/wiki/Sic
Old 09-28-2010, 12:39 AM
ericnova72's Avatar
More for Less Racer
You need to rotate the distributor counter clockwise to advance the timing on the Chevy V8. To install the timing tape, zero on the tape aligns with the factory line on the balancer, then the BTDC section of the tape continues clockwise around the balancer.
Old 09-28-2010, 06:43 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Turn the distributor CCW to advance the timing on the SBC.
Align the "0" on the timing tape with the line on the damper. The tape's numbers will show the degrees advanced if to the right of the damper line (or CW from the damper line).
When using the tape, use the "0 or TDC" mark on the tab to align w/the tape's numbers- disregard the other numbers on the tab- the tape now takes their place. ALL you need from the tab is an accurate "0" degrees (TDC).
Don't worry if it takes asking a few (more) times for clarification on this- it is a bit "quirky" to get at first- but if you stick w/it, it will make sense to you.
Edelbrock performer cam is a win spinn Engine 2 09-12-2010 02:50 AM
How to increase HP in a 74 2 bolt 400 CID seandiddy Engine 4 04-15-2010 11:08 AM
need info on Edelbrock rpm performer and.. ryork Engine 4 09-22-2007 04:23 AM
edelbrock performer upgrade scott ticknor Engine 8 07-25-2003 08:18 PM
performer rpm package 403_CHEVY Engine 4 06-27-2003 06:30 PM
