Buy which ever one of them is more expensive.
dont you know that secret? The more expensive the part is, the greater its performance.....name brands dont even matter (even though there usually the most expensive ones) just kidding.... get the one that makes you the "happiest" or blows your hair back, even if its the prm(per rotations minute)....... GM |
Are you sure about those heads? 200cc sportsmans is a LOT of head for that cam. Usually by the time people are considering 200cc heads for a 350, they're asking if they should do a Victor or a Victor Jr intake, but you're squarely in Performer territory.
I only say that to maybe save your wallet a bit. Consider that the sportsman 200cc head flows about 230cfm, and a bone stock 170cc Vortec head flows the same 230cfm with a full 30ccs less port volume. HUGE benefits in torque, throttle response, mileage, with no loss of HP. Plus with that cam, and vortec's nice fast-burn chamber, you can run 87 octane all day long at that compression. Those heads are mostly designed with beefy port walls and decks so that the option is there for racers to port the heck out of them and angle mill the decks. They are not designed as a performance head out of the box. |
Without a doubt the RPM manifold will be the best choice. It is much better at all points. Especially with the larger 200cc sportsman heads. Don't waste your $$$s on the lowly performer. You'd be giving up a lot of torque and power. The new Weiand Stealth hi rise is nice too. No complaints with the Pro Products Typhoon/Crosswind hi rise either.
I have used all these manifolds. Get a/the hi rise (rpm) type dual plane. It even idles better. A 750 carb is best. The cr could be higher. mill your heads to 68cc or get the 64cc versions if you have not already purchased. Sportsman II heads need a bit of port/bowl/guide boss clean up. Then they rock. Last edited by F-BIRD'88; 02-10-2009 at 06:51 PM. |
Well I know someone would say you kind of answered your own question but the rpm performer I am guessing it would give me a little more horsepower from 4000 to 5500 rpm. But I guess after of doing some more research I am going to go with the Edelbrock performer EPS intake wich will give me a little more torque then the performer and give me a little more hp.
As far as heads goes I was going to go with vortec but I don't like the lack extras with the vortec. If I bought a set of vortecs and got all the machine work done for guide plates and screw in rocker studs along with being able to put on double valve springs I would have over a thousand plus bucks and to me its not worth it. I was dong to go with World S/R torquer but buying the heads bare and getting the valve train parts needed cost more then getting the world product sportsman II's with the entire set up for a roller cam and it comes with good quality guide plates, screw in rocker arm studs etc. It will cost me less that way then the other ways. I know the intake ports area little big but it would not be much different wise then what the vortec's flow up to 500 lift. Thanks though guys for input all is welcome
Hey Fbird thanks for the reply. I guess then I will go with the rpm performer and its the same price as the performer EPS and you know your intakes better then I do. I am just a newbie here and am learning the trade. I will go with the performer rpm wich is the same one I have on my way more radical other s10 and I have been very happy with it.
Eric |
I have built and run these mild/moderate combos like you want to build. 350 flat tops with 64cc chambers 9.8 to 10.3:1 (not 9:1) The sportsman II's + RPM manifold work great. Vortecs work great too with a vortec rpm manifold. You can buy upgraded versions.( SDPC) or aftermarket versions (Enginequest EQ, GMPP bowtie vortec, RHS vortec 906) All these work best with a RPM manifold. The cam you choose is fine for either. Any/all of the low rise manifolds make less power and torque. The RPM type manifold does not give up low rpm power to a low rise. The only advantage a low rise has is low hood clearance. The RPM will fit under a low hood with the correct air cleaner. It (low rise) makes less power and does not have as good cylinder to cylinder fuel distribution as the RPM. if you are on a budget and have to make a choice, put the money into the better/upgraded heads, not the Hyd roller cam. If you are on a budget a hyd flat tappet Comp XE262cam or a Crane H278-2 cam #113801 both with a 1.6-1.5 split ratio rocker set will give equal performance to the XE270 Hyd roller. Use a 750cfm carb. The 600 makes a lot less power. The 750 is just as responsive (or better). There is no reason to compromise. Unless you want to wimp out and go slower than you could. The advertized rpm ranges are deceiving and will throw you off. The RPM hi rise type dual plane manifold (Edelbrock/Holley/Weiand/Pro Products) is the best of the bunch by far. Last edited by F-BIRD'88; 02-10-2009 at 07:21 PM. |
Hello Fbird thanks for the info I did not know that about the intake manifolds. I am going to go roller cause I already have that in my budget. I have yet to get the world heads but I am going to get them next month after I get my block here in a few weeks. I am just going to go with the sportsman II heads assembled with the roller setup. I just don't want the hassle with the flat tappet cams and I have the roller provision with the gm block anyways for just a little bit more. I had the sportsman II heads on a previous build and I loved them. Just wish I did not get rid of the heads I could have used them now. Thanks for all your help I will definitely get the rpm performer intake.
Take care Eric |
Hello Eric. I have a 355 in my 84 Monte Carlo and it is making well over 500hp with the following parts: Ross 10.5:1 pop-up pistons, Pro Comp 190cc intake heads w/64cc chambers, Comp Cams 292 cam, Edelbrock Victor Jr. intake, Holley 750 Double Pumper, Mallory distributor & coil, Hooker Competition Headers, 3.73:1 posi rear end and a B&M 3200 Stahl Converter. Runs on 91 octane pump gas. This combo is guaranteed to put you back in your seat. I hope this helps out.
Yeah thanks for the reply. I bet your engine runs really nice. I have went with the edelbrock rpm but since changed to the edelbrock eps intake because of it being tuned to get your peak horsepower around 3500 rpm. I compared it to the edelbrock rpm and it's about basically the same thing.
It is the same height as it is. I thought I had a fuel delivery issue with my performer rpm and I wanted something to give me a lower peak torque curve to go with my smaller cam I went too and the eps is marketed as such but really I don't know the difference between the two. To me they are basically the same intake just maybe a little difference in the inner intake tunnels. Just having some issues with my stupid motor and trying to find out a stupid miss that is getting worse and whats causing it. That is a complete other post. Eric |
I think you would see a big improvement if you went 1 more step up with your cam (next larger cam) and the victor jr. intake. It would make a pretty big difference and it should work well with the heads you are using.
Nah I don't need anything bigger then what I have for an everyday driver. My 96 s10 is plenty fast and good with the setup I have with it now. I have a way more aggressive performance motor in my 86 s10 with about 100 more ponies under the hood.
Eric |
| Holley Contender 300-36 SBC intake questions | BinderDriver | Engine | 1 | 03-13-2008 05:19 PM |
| Edelbrock Aluminum intake | King Kong | Engine | 6 | 01-03-2008 07:29 PM |
| sbc intake tips needed | jw4413nv | Engine | 1 | 05-23-2006 09:45 AM |
| Edelbrock Intake | Thacolbster | Engine | 4 | 12-24-2002 06:58 PM |
| best edelbrock intake for this setp | oldcarguy85 | Engine | 5 | 04-25-2002 07:04 PM |
