Edelbrock Performer RPM cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2008, 02:34 PM
I am considering this cam in my chevy 350. The combination i am running is vortec 2.02 heads, Edelbrock RPM air gap manifold, 1 5/8 headers, Holley 650 carb and turbo 400 with a 2200-2400 stall. I am looking for a cam that will make good street driving low to mild range power with a nice musclecar type lopey idle. can anyone give me there opinion on this cam or what you would recommend. Thanks
Old 10-06-2008, 03:02 PM
F-BIRD'88's Avatar
Yada Yada Yada
Needs a 3500 stall 10" torque converter.
If you want to use a 2200-2400 stall converter, use a crane #113801 HMV278-2 cam.
or a Comp cams XE262H-10 #12-238-2
Old 10-06-2008, 03:43 PM
ran that cam in a 327 with 10.5 compression 3500 stall at minimum
Old 10-06-2008, 10:58 PM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
I run that cam in my 406 and can tell you that it pulls really well from about 2300 on up (Mine installed 4* adv.) but doesn't really have a lot of "lope" to it, at least not in my 406. Might have a bit more in 350/355 simply due to "looking bigger" to a lesser-cubed engine. That particular cam does have a very nice broad powerband to it, and in fact thats the reason I chose to run it in mine. -Jim
Old 10-07-2008, 06:24 AM
TroyBoy's Avatar
Psychomotors
I have a 350 with that cam,750 dp,vic jr intake,1 5/8 headers w 2 1/2 exhaust into flowmasters.TCI 2500rpm Breakaway converter w/ 350 th, 215 Dart iron eagles 2.05/1.60-64 cc and TRW ft pistons all in a 79 Malibu with 2.73 gears(I know ,I know )It will flat out blow the tires off at any RPM and sounds Damn good doing it I think you will like this cam
Edelbrock performer rpm cylinder heads SBC monzter Engine 25 08-19-2008 12:26 AM
Performer RPM springs with XE274 cam? v8hed Engine 1 06-26-2008 10:29 AM
Edelbrock Performer Cam vs. ... hillman88 Engine 21 05-13-2006 08:06 AM
vortec heads on sbc 400 camino_man Engine 16 11-11-2005 01:33 AM
Edelbrock Performer 390 vs. RPM Byrdie Engine 5 08-09-2004 07:02 PM
